I finished installing my HID's and now the gauge cluster won't light up, everything works fine except it won't light up. Also...my right rear light won't light up either, the turn signal lights up, the break light lights up, but the other light won't light up. I checked the bulb...it's fine, are the gauge cluster and right rear light on the same wire.
I hope it's not because of the HID's.
P.s. How do you disable DRL with the normal switch?
