1 - 9 of 9 Posts
The car DOES turn on, though and my radio works.
This is NOT the first tim this has happenned in my new model 1999 jetta vr6 ...and i DONT have an aftermarket radio deck in there, either.
WHat gives? I would apprfeciate it.
Re: My headights wont come on, ac fans and turn signals dont work..IGNITION SWITCH?? (highwatt)
For a newbie, you've been reading up... it may, but the radiator fans are not affected by a faulty ignition switch.
Sounds of more of a relay issue or blown fuse; assumed you check those haven't you?
And the e-brake if completely off? Get back and post more details...
- Erik
Re: My headights wont come on, ac fans and turn signals dont work..IGNITION SWITCH?? (bluefox280)
Not so mucha newbie as a frustrated owner...Thsi would be the thrid ignition switch that has gone into this vr6. the last effort to replace the switch ended up with me at larosn vw of tacoma (again) to replace, as you so astutely called it....relays.
The second switch was actually "melted" at the connectors, if thats the closest lingo I have.
I have replaced the MAF and the O2 sensors twice already.
If I had my gumption, lobbyist-style, I would garner some attention toward protecting consumers from NON-USER related issues, especially ones that frequently happen, even after warranty.
I APPRECIATE YOUR INSIGHT, ERIK. Thanks. And oh yeah, fuses are fine (of course they are!)
Discussion Starter · #4 ·
wait a second...did you say the radiator fan is what drives the air conditioning and heat to come out of the vents???
hhmm...
Quote, originally posted by bluefox280 »
- Erik
No one said anything about radiator fans??
Please dont confuse this guy because you have no idea what you are talking about
Banned
Re: My headights wont come on, ac fans and turn signals d ... (ThisAin'tNoCivic)
yeah rad fans
uuhh, what. anyway. wait you have a 99.5. 1999.5 Jetta GLX VR6
dude is it a mk3 or a mk4. either way sound like an ignition switch to me.
Modified by havok917 at 4:09 PM 5-20-2004
Modified by havok917 at 4:10 PM 5-20-2004
Quote, originally posted by highwatt »
No, that the HVAC blower motor, much different from the radiator fans behind the radiator.
Quote, originally posted by ThisAin'tNoCivic »
No, I read highwatt's post incorrectly... I was dealing with some cooling threads previously.
So, not the radiator fans, but the cabin blower motor... that's what was the miscommunication.
- Erik
Modified by bluefox280 at 2:32 PM 5-20-2004
Discussion Starter · #8 ·
Re: My headights wont come on, ac fans and turn signals d ... (bluefox280)
so again...for my own insight and not to be confused by this frenetic thread of disoucrse...
does the ignition switch affect the cabin motor blower?
just trying to put some things into english here...thanks Erick.
ignition switch it is, i had same problem, the thing is i found out a lot of it has to do when u start the car, instead of turnin the key right away, u actually should push it in then turn the key, but ur problem sounds like ignition switch to me too aight peace
Wes
1 - 9 of 9 Posts
