1 - 1 of 1 Posts
MY radio reads .wav files. does that sound right? Regular Premium 8 radio no amp or 3 way fronts.
Just 2 way passive front and rear.d
it reads them right off the SD card.
Also is the best way to add aftermarket amps sub speaks etc. would be to solder RCAs onto the high level wires and then go into VCDS and change the sound system to VW OR DYNA AUDIO?
OR is it ok to run the high level front and rear wires to an Lc7i and then to amp and leave VCDS alone?
Thank you for any insight
1 - 1 of 1 Posts
