Re: My Oil Catch Can turned Oil Air separtor (ThatGuy)
Quote, originally posted by ThatGuy » |
so does this just hang on the supports that you made? |
Yeah the can just attaches to the brackets via a large hose clamp.
(I added a small piece of Mouse Mat foam between 'L' braket and Can so as not to damage the alimimum can side when tightening then clamp up.)
There are 2 'L' brackers fixed to the mounting plate.
Parts:
One of the 'L' brackets has a curved face to fit the side of the catch can.
Okey Dokey... Did a Pela Oil change on Thursday Night... Took some pics of the can and what it is doing.... eeekkkk!
Well it is working:
CCV output tube is covered internally:
A close up of the Tubes... White Paper is behind so as to give a clearer picture and som contrast. I have some oil splattering back out of the Catch Can
A closeup of the inlet/outlet port on the can...
I do not know why the outlet is getting oil splatters from the can.
The Inlet is designed so the vapours are forced too the bottom of the can (via the copper tubeing I added) then all the vapours will then have to pass through all the Stainless Steel Wool before exiting from the top port. The can is not full of oil... but the principle of the can is working... filter the vapours and try and collect/extract the oil.
So why the splattering?
I have to take it off and have a look...
... and while I'm there fix a leak in one of the threads... I need to add some Plumbers Gas or Water tape to all the treads as oil has seeped onto the side of the can from the inlet port.
Modified by Gigitt at 12:42 AM 8-14-2008
