Just a small update from the weekend. Car has recently started running poorly occasionally and I didn't think much of it, figured probably some vacuum line leaks that I would get to eventually. Well this weekend it just struggled to start and when it did it ran good for a few mins before bogging itself out and running like garbage or just completely bogging out and shutting off. OK, its more than just a vacuum line issue. Grab my compression tester first and run a test on all 5 cylinders, were good. While pulling the plugs I notice one looks absolutely brand new. Dammit. Check spark, we're good, pull injectors it looks like it hasn't sprayed in a while, its dirty, not great. OK so we have an injector issue!
Things came up and I hit pause so next I need to find a shop to test/rebuild my injectors and at the same time check the voltage to the injector connectors and make sure we're getting power. In the meantime I should probably also double check the distributor and make sure that is all good too.
Any other ideas always welcome! :beer::beer:
