Re: My Passenger Door Panel Buzzes! (sinthome)
quote:[HR][/HR]thanks for describing your setup. i'm having the same passenger's side buzz on my 2002 passat; it was there when i had the factory HU in and still there with the Blaupunkt San Jose (which was a no-brainer to install with crutchfield's harness kit, in case anyone's wondering, and it's a pretty sweet HU, plays mp3 and wma formats in addition to regular cd's.), no matter how i futz with the settings. Although aside from the buzz, the sound is much improved over the factory HU. Anyway, the San Jose has sub preamp outputs and now i know what to do with them, thanks to your very clear explanation.[HR][/HR]
however, after i put the sub in the trunk, the rear deck (parcel shelf) vibrated so bad you could actually SEE it jump up and down... i had to remove it, get some foam and pad the bottom of it and stuff foam around the edges after i put it back in to get rid of that rattle. obviously thats alot easier than taking apart the door. the rear deck in the jetta comes off very easily.
[Modified by turborave, 2:37 PM 11-29-2001]
