1 - 5 of 5 Posts
Well one day I decided to put my car to the test and every since then my pedal feel a little loose... every time I tap the gas for slight acceleration It feel like my pedals shift to the side a slight bit... not too much, just enough to annoy me... anyone know how to fix this... is there an adjustment for pedals? Its both the gas and brake pedal... and also when I kick my AC on when I shift gears I feel a slight hesitation... smooth when AC off though.... is it just me or what? This is going to be my first summer with this car so Im just wondering... that and the pedal issue.
Discussion Starter · #2 ·
Re: My pedals feel loose... help please. (beetle18t)
It started after I shifting into third kinda hard... grinded a little... like I forced it in there.
when the AC is on, the car does lose a little bit fo grunt, it's not just you.
Re: My pedals feel loose... help please. (schtebie)
there is a bracket that goes from the clutch to the brake pedal, make sure it didnt 'disapear' like mine did and make sure both nuts are tight...with a loose bracket your pedals will shift when you step on them and could cause grinding since your really not pushing the clutch in all the way as you think.
1 - 5 of 5 Posts
