My wife bought an '88 Cabby (auto) a month or so back to use as her daily driver. The thing has absolutely no power, so I want to do a general tune-up on it; plugs, wires, timing, filters, oil, etc., in hopes of regaining a little pep. Any tips and/or tricks I can do to squeeze a bit more power out of it while I'm in there?
Also, what holds the bearing in at the bottom of the steering column? I noticed some play in the steering wheel and when I looked under the dash to check it out, I saw that the bearing had slid down to the joint on the steering shaft. I was able to slide the bearing back into the column, but it doesn't stay.
Thanks.
Thanks.
