1 - 2 of 2 Posts
I heard Wilson is the man to answer this question, but lets see who else knows. Stock resistance is between 25 and 35 ohms? Which way, or higher/lower adjustment for surging? Do I need to approach the 25 or 35 ohm reading to combat some surging.....I get this boost, then hesitation, then boost again all within a second or so.... So I can test my N75 valve and determine the base (stock adjustment) and adjust from there, but in which direction? Higher or Lower?
Re: N75 Adjustment (Boggus)
If you have an AWD engine, 25-35 is the right range. If you have a multimeter, just try it at both ends of the spectrum and see what happens. I would stay between 25.5 and 34.5 just be safe.
1 - 2 of 2 Posts
