1 - 8 of 8 Posts
They sure don't build them like they used to.
Specs:
Type: 12 cylinder inverted-vee
Bore: 150 mm (5.91 in)
Stroke: 160 mm (6.30 in)
Volume: 33.9 l (2070 cu in)
Weight: 600 kg (1325 lb)
Power (601 Aa): 865 kW (1175 HP) at 2400 rpm
Continuous(Aa): 735 kW (1000 HP) at 2400 rpm
[Modified by Lexi, 9:06 PM 11-26-2001]
Discussion Starter · #6 ·
Re: Name that engine... older German trivia edition (MrRoboto)
It's a Werkphoto™.
It's a Daimler Benz DB-600 series.
QUOTE]
I shoulda cut that part out, good eye !
One of my favorite aircraft of all time. Back when flying was an art.
E82M Coupe, A177 A35 Hatch
Re: Name that engine... older German trivia edition (Crazyquik)
quote:[HR][/HR]Whats the advantage of an inverse V than a standard V?[HR][/HR]​
My understanding was that the inverted V allowed for a higher crankshaft position. This allowed the usage of larger propellers with adequate ground clearance.
yup and the larger prop generates the same amount of lift at a lower RPM than a smaller prop does.
1 - 8 of 8 Posts
