1 - 4 of 4 Posts
ok..I've found most of the engine spec info on the web...but the following I can't find anywhere...I'm wondering if anyone here knows where I can find these specs for my '97 2.0L:
Intake + Exhaust valve size
Approx. induction flow (cfm)
those are the important ones that I need...but if someone knows the stock cam specs too I'd appreciate it.
Thanks in advance for any info you guys can provide.
Re: need 2.0L 8v (mk3) engine spec info: pls read... (DJHaveK)
Stock intake valve diameter is 40mm
Stock exhaust valve diameter is 33mm
Both have a 7mm stem if I am not mistaken
Stock flow on intake and exhaust can be found on www.porttuning.com...specifically at http://www.porttuning.com/Flow 2.0 8V X-flow.htm
Modified by bajan01 at 6:47 PM 5-19-2004
1 - 4 of 4 Posts
