1 - 9 of 9 Posts
I recently bought a dark blue 2000 Jetta. The previous owner had a roof rack on the car, which I took off after purchasing. It turns out that the rack has left cloudy (not sure if this is the right term) marks on the roof where it made contact with it. How can a remove these marks? I do have a cheap random orbit buffer if that will help.
Also, there are a couple small scratches on the car, can I use the same method to fix those as I can to fix the damage from the roof rack?
Sorry if this is a repost
Re: Need Detailing Advice (CGlass 1.8T)
Even a cheap R/O is better than none .. You might want to try Megs. DACP on the cloudy area. The scratches .. can you catch your fingernail in them?
DACP will clean up a lot of the scratches too.. If you can't get DACP go with 3M SMR for dark cars. It has a lit of fillers so check your work carefully the follow up with your wax of choise.
Discussion Starter · #7 ·
Re: Need Detailing Advice (Jesstzn)
Any suggestions on where to purchase this product? Also, is this something that is applied by hand, or with the buffer?
Thanks for the help
Quote, originally posted by Jesstzn »
Dual Action Polish & Cleaner
Who makes this product, and where can it be purchased?
1 - 9 of 9 Posts
