1 - 2 of 2 Posts
im just finishing up my vr6 swap into my 96 jetta. after fiddling around with that puzzle of a fuse box, i believe i have all connectors where they should be.
my rear parking lights and brake lights work, but none of the front lights work at all (including headlights, turns, fogs, parking lights). if it makes a difference, other things not working include winshield wipers and sunroof.
i have a 2 hour drive to make tonight and need to fix this asap. im thinking its a ground im missing or somthing, but i dont know where to start and the bentley manual didnt help too much either.
Re: need help asap. no headlights, front turns, parking lights (DankNugz)
My bet is the ignition switch, and you only need to remove the steering column clam shell to pull the ignition switch connector, plug it in to the new switch, and check it out, but I believe it to be that part. It's cheap to buy, less than 30.00...
Mike
1 - 2 of 2 Posts
