1 - 4 of 4 Posts
ok so i have an a2 gti vr6 i had the stock cluster in it and nothing worked, so i decided to put a mk3 vr6 cluster in it i swapped the harness out for the cluster as well as the harness for the stalks, i jumped the pins now when i turn the key on the cluster lights up fine , but when i turn the key off it goes blank again. also im trying to get the mfa hooked up and im questioning if it will work because im running a 96 passat engine harness.... so i have a cluster that turns off when the key is off, no blinkers, and no mfa. i researched a little bit but im sure someone can help me out.....thanks :beer:
1 - 4 of 4 Posts
