Hi Everyone,
So I'm thinking about buying an already fairly heavily modded 84 Rabbit GTI track car. Given that "reversing" some of these mods out of the car would not be an option due to a lack of stock parts or difficulty (i.e. I do not have a full stock interior for it) I can't really see myself trying to remove parts and bring it up to a different class level. So for the most part "it is what it is" to me at this point. Frankly the point of me owning it is to have FUN with the car. I will not be butt hurt if I am noting winning autocrosses with it. I will also be trying to do some occassional HPDEs with it as well.
I would like to get some advice on what class it would be considered for SCCA, and what kind of competition I would probably face with it.
So here's the full mods done to it:
Engine
Modded airbox
Dubspeed intake
Audi 5K throttle body w/ ported intake manifold
TT 280 cam & valve springs
Pacesetter header
BFI oil pan and windage tray
Neuspeed adjustable cam sprocket
Autotech intermediate shaft sprocket
G60 valve cover
Eurosport "Race" Exhaust
USRT short shift kit
Autotech 10.4mm plug wires
16V clutch
Eurospec litghtened flywheel
ATL "Well Cell" Fuel Cell
ATL surge tank
Aeroquip braided stainless steel fuel hoses
Aeroquip aluminum fuel line fittings
Allstar Performance valve cover breather catch can
VW Motorsports Tranny mount
Poly motor mounts thoughout
Wheels and Tires
15" Jax Light wheels, 205/50 Falken Azenis
Chassis
Custom made lower 4 point X brace
Poly steering rack bushings
Eurosport upper strut brace
Eurosport rear strut brace
Hawk HPS front pads w/ slotted rotors
Scirocco 10.1" brake swap
Tilton proportioning valve
Battery relocated to p/s floor board
Neuspeed Race springs w/ Bilstein Sport shocks
Neuspeed rear sway bar
Exterior
Hella e-code lights with Sylvania Silverstar bulbs
Clear turn signals
deleted rear wiper
Cabby tail lights will filler panel
OMP hood pins
scirocco single wiper conversion
Allstar Performance master battery disconnect switch
Interior
Schroth Rallye 3 belt
Corbeau Forza seat
Autometer shift lite
Autometer Pro Comp gauges (oil temp, oil pressure, volt, water temp, fuel level, A/F ratio, tach and speedo)
Longacre Ignition and start switch panel
STRIPPED interior (dash, seat and door panels are left)
So what do you guys think this would fall into for an SCCA class?
What kind of cars would I be competing with in this class?
Any advice is greatly appreciated.
Engine
Modded airbox
Dubspeed intake
Pacesetter header
G60 valve cover
16V clutch
ATL surge tank
Wheels and Tires
Chassis
Exterior
Clear turn signals
deleted rear wiper
OMP hood pins
Interior
Corbeau Forza seat
