1 - 5 of 5 Posts
Need Help disabling DRL.. I tried taping the TFL pin, but still no luck..
I tried to disable my DRL today and am not having luck.. The car btw is a 2001 NB TDI. I tried as per my search on the forum, to tape up the TFL pin on the headlight switch and that didn't work so I just tried to cut of the wire leading out of that third pin and still no good.. What am I doing wrong? Is there a different way of doing this ie. cutting a wire at the headlights? Thanks in advance
Re: Need Help disabling DRL.. I tried taping the TFL pin, but still no luck.. (Harajuka)
i just unscrewed the panel under the dash on the driver side and pulled out the relay marked #173. This will disable your DRL. The only down side is that the thing won't light up to tell you that the emergency brake is on.
1 - 5 of 5 Posts
