Need Help for wiring Hella Micro DE Fog : Relay blowing fuse
495 Views 5 Replies 4 Participants Last post by  HsuJA
2
Hi ! I need u guys help. I can't figure it out what's the problem.
Here's the case : I just installed the fog light a week ago. everything went ok. I could turn them on without problems. But since the second day the relay that comes with the kit doesn't stop blowing the fuse. I have already replace the fuse a couple of times but that doesn't work. I have tried plugging the positive wire in the (small box on top of the battery on the most right wire) (I dont't know how u call it) that doesn't work either! any glue ? please thanks...
any help would be appreciated.
See less See more
1 - 6 of 6 Posts
Re: Need Help for wiring Hella Micro DE Fog : Relay blowing fuse (HsuJA)
SoundZero had some issues with blowing a fuse with his DE install. im not sure of the situation surrounding his blown fuses but do a search for his posts and it may help you out.
See less See more
Re: Need Help for wiring Hella Micro DE Fog : Relay blowing fuse (swmacneil)
thanks, but i can't find anything for my case ...
See less See more
Hey,
The fuse in your relay is 15amps. I ended up bumping the fuse up to 30amps. Also, both of tapped wires are grounded on negative connector.
Fuse#36 in your fuse box is for the fog. You need that to be replaced to 30amps if you bridged the Hella DE fog wire into OEM fog wire.
Shoot me a message if you have anyother question.
[Modified by soundzero, 10:37 AM 11-27-2001]
as well double check your wiring..it might be that too.
if u need help, i can try to meet you to help u out.
seeing as how u got yours from my GB, i feel a bit responsible
let me know
3
Re: Need Help for wiring Hella Micro DE Fog : Relay blowing fuse (VR6 Kid)
Thanks guys ! I just solved the fog light problem. There were some small pieces of metal in the fog light that was shorting out the fuse. i haven't thought of cleaning the fog when i screw them on the grill. Those metal must come from when i put the screws. After i opened the fog housing, i remove the metals and put some electrical tape aroung the plastic tube. Everything is ok now. Thanks for your replys. My car looks much better with DE fogs
http://****************.com/smile/emthup.gif but i still find that the light output (headunit and fog) is not that great. Maybe i'm asking too much.
oh well probably i'll get some e-code...
See less See more
1 - 6 of 6 Posts
