1 - 14 of 14 Posts
I am only seeing 16 psi spikes and holding at 13 psi. Everyone with GIAC 1.1 and APR chips (with stock IC) are saying they see 19-20 psi spikes (not that thats good, but...) and they hold at 15-16 psi. I am thinking its my FMIC causing pressure drop. any ideas??
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (VWTornado)
nevermind...
Dunno, cars adapt to different conditions. Boost is a factor of a requseted load. If the ECU sees that load with only 16psi, then it won't get any higher. It can change as the weather changes. I bet when it warms up, you get 19 psi.
Or, you could just have a boost leak...
[Modified by 1.BillyT, 7:19 AM 2-11-2002]
is there a way to Vag-Com boost pressure? If so Shaun maybe we need to test my car to see what it's putting out - to be honest yesterday the one time you accelerated hard you car felt A LOT stronger acceleration wise than mine did - I don't think you have any boost problems at all........maybe a leak in the gauage line or something?
Dan
Blackwing, Model 3, S2000, i3, Odyssey
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (JettaManDan)
quote:[HR][/HR]is there a way to Vag-Com boost pressure? If so Shaun maybe we need to test my car to see what it's putting out - to be honest yesterday the one time you accelerated hard you car felt A LOT stronger acceleration wise than mine did - I don't think you have any boost problems at all........maybe a leak in the gauage line or something?
Dan[HR][/HR]​
Just log magic channel 115- requested boost and actual boost.
-Nick
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (GTI 20v)
Dan
-Nick[HR][/HR]​
thanks - we are doing a dyno day on this saturday and will hopefully have a Vag-Com as well as dyno results........
Did you put on that damn blow-off valve again. I thought it made your boost drop with the autothority chip. I am not technical, but if it happened before with the bov/autothority and it happened again with the bov/giac I think we can narrow the problem to that area
Discussion Starter · #8 ·
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (4DoorSleeper)
quote:[HR][/HR]Did you put on that damn blow-off valve again.[HR][/HR]​
No scott, its NOT THE BOV!! This boost was happening with Forge DV in also. The weird thing is the car is still VERY fast...even with only showing 13 psi holding.
I see your problem now you have v6 shaun, upgrade to version 10 and you will see big spikes when I drovw Pat01aww car with DP and v10 I saw a 23psi peak and it help 1 bar all teh way up
Mike
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (VWMike81)
I have herd the same fromt the new APR versions they eliminate the big spikes but run better and just as fast if not faster but I never herd of a version10 GIAC Whats that program I thought the newest was v6 isent that a race version? what about just going back to GIAC version 5?
I am
Re: Need HELP from people with GIAC 1.1 bar and STOCK Intercooler. (George Bush)
If you're clueless then don't chime in. Version 6 is the smoothest chip, but does not have the torque down low or the top end of 10, although 6 has a better top end then 4 IMO. 10 is the newest chip out there. Also there is no race chip for AWW motor's
Mike
quote:[HR][/HR]ttt, any other ideas?
[HR][/HR]​
Check the PCV T juction under the manifold, the "bleeder" pcv valve goes bad after a while, creating an oily mess. 13K miles on mine went kaput, the valve actualy leaks when new, go figure. I have since disabled, no problems so far.
yes, there is a way to measure boost, load etc with the vag... Jay 24 ran that on my car on Sat after he helped me install the APR chip. I believe he will be up there on sat.
Also, I think there may be others bringing Vags too, so don't worry!! Hopefully we can get you striaghten out on Sat!!
1 - 14 of 14 Posts
