I need a little help. my 91 jetta gl keeps blowing the fuel pump relay. does not blow the fuse and if i put a new relay in the car will start and run. the next time i start it it you can here the pump come on, the car will start but will quit shortly after that. when you try to start it again you can here the relay click but no fuel pump noise. any suggestions? Thanks
