what is the best kinda drill bit to use ?
i found it extremely difficult to drill through the strut towers for the nutserts
after the holes are drilled it seems simple
just tighten everything up !!!
Re: need help installing Eurosport front strut tower bar (VRsixVW)
well you can use any drill just make sure it has enough power to drill through metal and also make sure you have some good drill bits and make sure you also drill straight other then that its not to hard. As for drill bits I think I used titanium but it was awhile ago so I cant be to sure.
I'd start with a smaller bit than they tell you to choose, and work your way up. It may take a little longer, but that is what I did, and had no problems at all
