Re: need help now big problem (killthecivic27)
Is the V-Belt tight or even on there? do you have P/S fluid? the pump may be shot.. not sure about the radiator, you gotta look and see where its coming from, try to get it up on a lift. if your not gonnna do the work yourself i highly reccomend you take it to V-Shop in Kendall. Mechanics name is Eric, does good work.
