1 - 5 of 5 Posts
Ok heres my situation, i removed my Neuspeed SC setup, after getting everything back to stock, i hooked up my Idle Air Control (IAC), i cannot find the harness to go into the IAC motor because the SC doesnt require running an IAC, does anyone that runs OBD 1 know where there harness runs from?? If you dont know, it be greatly appreciated in you could just take a look and track it back to its source. This is causing my idle to go crazy, car runs fine just at idle it jumps around like crazy, after it settles its still idling real high. Any help is greatly appreciated, thanks guys.
Re: (bronxbombers689)
the IAC motor control harness is part of the "Cylinder Head Harness".
Basically, from the twist off connector on the dirver side of the block. It's part of the TPS, 4 injector, IAT sensor, grounds, and Hall sender harness.
1 - 5 of 5 Posts
