1 - 7 of 7 Posts
Control Module Part Number: 06A 906 032 RN
Component and/or Version: 1.8L R4/5VT G 0001
Software Coding: 07510
Work Shop Code: WSC 12850
1 Fault Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
So what's crackin with this code I pulled of VAG-COM?!
Vendor
ID.4, 997.1
Re: Need help understanding this code P0130 (frprado)
#1) Why do you feel the need to bump your own thread twice in one day, despite the fact that it is still on the first page?
#2) Let's take a look at the text that VAG-COM gives you:
P0130 - 35-00 - -
Your front oxygen sensor (Bank 1 Sensor 1) has a malfunction in its circuit with the ECU. So, the possibilities (in order of likelyhood are): bad O2 sensor, bad wiring between O2 sensor, or bad ECU.
Vendor
ID.4, 997.1
2:10 AM 10-11-2005
10:19 AM 10-11-2005
2:47 PM 10-11-2005
You bumped your own post twice within 13 hours, is that better?
Discussion Starter · #7 ·
Quote, originally posted by frprado »
3.) Thank you
1 - 7 of 7 Posts
