Re: need help with brake bleeding (pt_08)
I'm not sure whats going on or what method you are using, you should have no problem whatsoever on either of the front calipers. The back ones can be tricky because of the proportioning valve if you don't tie it up.
Pressure bleeding is the way to go. The ones that connect to the master cylinder that you pump up are the best, what i use is a hand operated vacume pump at the bleeder to suck the fluid out.
Again, i don't know why no fluid would flow in the front unless something is pretty wrong.
