I have a 2003 GTI VR6, with over 24K miles. The coolant level, when cold, was always just below the MAX level in the overflow tank. About a month ago, I backed the car out of the garage one morning, and shifted into first. The coolant light began flashing and the chime went off. I stopped and checked the coolant level. It was below the MIN mark. I pulled back into the garage and added distilled water to bring it up to the MIN mark. (I didn't have any G12 coolant at the time.) It took 6 ounces of distilled water. The light did not come back on.
Since then the coolant level, when cold, is usually half way tween the MIN and MAX marks. But, sometimes its at the MAX mark and sometimes it's 1/4" below the MIN mark (altho the light does not come on). The temp gauge reads at the right end of the 190 degree hash mark. The car does not overheat.
Why don't I have a similar amount of coolant in the overflow tank each morning? It would seem that I don't have a coolant leak. It would also seem that if the amount of coolant in the system is constant, then as the overflow tank amounts vary, so do the amounts of coolant in the radiator and engine block. The dealer says the cooling system is operating perfectly (they don't understand why the overflow tank amount varies either), and to keep an eye on the overflow tank amount.
Any thoughts or ideas from anyone? I just have this idea that something must be wrong or I wouldn't have the overflow tank fluctuations that I have on an almost daily basis.
Modified by dmkozak at 12:21 AM 12-14-2004
