1 - 4 of 4 Posts
ok well I bought the led kit from VentoGTD about 2 months ago and decided to tackle this now. I took apart the cluster and removed the top white plastic so I could remove the green diffuser.
I replaced it with the blue LED boards and diffuser he gave me but I am stuck at one point, where and how do I run power to them? The bulbs that were there had no wires as I assume they got power from the paper curcit board. Each LED board has 2 wires running from it so I need to know where and how to wire them?
Anyone know this?
Re: (GolfGLSGirl)
Ok in my cluster I used clips like the blue ones to tap wires coming from the headlight switch. use the - to the brown ground and I believe that the light blue is the dimmered interior lighting. attach the + there..
1 - 4 of 4 Posts
