1 - 4 of 4 Posts
Have a new set of the xeon Hid Micro De in lower grille.They bolt up fine and look good ,but the beam is way to low.There doesnt seem to be any way as I can see to get them to move up higher.Its a very tight fit in where the housing is and the grille.Somone have any ideas with this.
Re: Need help with Micro DE Beam Alinement (ucmyjetta)
I have a TDI too (but a Golf) and have the same problem, they're just a LITTLE too low, but they won't pitch up because the large wire connectors are hitting the frame on the driver's side and the air baffle for the IC on the passenger side. I'm gonna go at the baffle with a dremel this weekend, but the frame has me vexed. They look great, but aren't very functional right now as the beam cutoff is about 4 feet in front of my car
I'm sure it's fixable, I just had enough after slicing my left hand and having to do the job (in the cold) with one good hand.
1 - 4 of 4 Posts
