1 - 2 of 2 Posts
INSTALLED GAUGE I HAVE TWO GAUGES WHICH I HAVE TEST WITH AUTOMETER AND A VDO BOTH AREGOING CRAZY I MIGHT HAVE A 16V SENDER NOT SURE BUT I HEARD U CAN USE THE STOCK SWITCH IS TRUE AND IF SO CAN SOME ONE HELP PLEASE IM ME ON HERE OR AT [email protected] I KNOW IM NOT CRAZY JUST NEED TO REFFERENCE SOMEONES INSTALL ALREADY THANKX
Re: NEED HELP WITH OIL PRESSURE INSTALLLL (SLAMNGTI'S)
caps lock http://****************.com/smile/emthdown.gif i just got my oil pressure gauge installed today...its an autometer phantom elec. 0-100 psi.. did you buy your gauges new or from someone else?? because i dont know why they would make a sender specifically for a 16v engine. use the sender that came with the gauge when you bought it. there is no sender that came on vr's unless you have a corrado that came stock with the oil pressure gauge..i believe you can use that one as long as its with a vdo gauge but not sure hope this helps
1 - 2 of 2 Posts
