I have a 2003 Jetta TDI that I bought about 2 months ago. I had the fuel filter, timing belt and air filter changed at that time since it had 60,000 miles on it. Everything was running great for at least a month when I noticed the following problem the first cool morning this month.
Here is the problem in a nutshell: The car starts up fine, but when I try to drive it it won't go above 1200 RPM's no matter how much I depress the gas peddle. There is NO power and it eventually sputters and stalls out. I can immediately start it back up and the same thing will happen. It has been cooler this last weekend and this morning it happened again (another cool morning) and the MIL light came on as well.
When I got home this afternoon it was warmer. The car started up although it sounded a bit rough and was smoking. The exhaust smelled really strong too. I made it to Autozone where they read the code P0252: Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector).
Has anyone seen this one before? I have done some research and can't find much about this code. I was kind of hoping it would be the MAF sensor since that is still under warranty. Any help that anyone can offer would be so much appreciated as I will be riding my bike to work until I get this fixed.
Thanks,
Karla
Thanks,
Karla
