Need Help with Passenger Side Power Window
I have 98 GTI and passenger side window isn't working properly. It will go up and down but it gets stuck and makes a pretty harsh noise when going up. I noticed the window appeared to be a little loose, like you could pull it up 1/4" or so. Took the door appart and couldn't figure out a way to adjust that if it is possible. Any clues if this can be adjusted or is a just worn out parts?
[Modified by jkochis, 4:43 AM 8-6-2002]
