Re: Need help with relay ID (J.Knipl)
Looking in my Chiltons manual, the coolant low level sensor G32 comes from wire #31 which is GND, then goes through the sensor (also coolant temp sensor G2, and follows wire "L" which goes to G54 speed sensor (WTF?) and then to G1 (fuel gauge) which makes hell of a lotta sense. There is a coolant temp gage G43. Anyway, basically the wires go straight from GND through the sensor and to the dash gauge, so no relay. Remember relays are for switching high current loads, a gauge isn't a high current load, in fact super low current. There's a radiator fan cooling relay, that's about it. That's relay #13 or above the fuse panel and left most side. Sorry, can't be of more help.
