1 - 5 of 5 Posts
im buying a set of esm no.2 wheels for my 88 coupe with 98 glx 5 lug im goin 16x7 in the front and 16x9 in the rear what offset and center bore do i need i had issues with ne no.9 wheels on a 97 glx the rim didnt clear the front caliper even with a 1/2" spacer i had to grind em down a lil
jbigs to the rescuuuueeeeee
:wave:
I ran ESMs 002 in a 16x7.5 et20 and a 16x9 et20. Note, i do not have a vr, so spacing front and rear will be a little wider thus making you need a little higher of an offset to fit like mine. Also, i was running 2.6-2.7 degrees of negative camber in the front.
For a 16x7, i would go for an offset anywhere from et10-20. For the 16x9 i would do et20-30
And the center bore is 57.1mm.
Need anything else, shoot me a PM :thumbup:
1 - 5 of 5 Posts
