all my previous turbo cars always had a distinctive whine associated with the turbo. i would like the 1.8t to be louder in that restrospec.
two concerns though....
1. i believe i would need a filter on the end of the turbo intake but the intake tubing has some stuff i would need to reroute. any ideas on rerouting so i can put a filter on the turbo intake? i think BOV and ecu tune for BOV would be the only option
2. the stock turbo is small so i assume it wont make as much noise as a t3/t4.
edited: updating thread and cleaning it up with informative answers.
1. TIP turbo inlet pipe, around 140
2. bigger downpipe
3. bigger turbo or BT kit
4. air intake of some sort.
5. remove some sound deadening material from hood area along with windshield cowl.
uncommon answers that may get the job done but are somewhat risky...(CEL, running problems etc...)
6. bend some fins on the turbo itself. (may cause turbo fins to be unbalanced and wear out your bearings faster).
7.run open turbo intake, may cause CEL due to how the MAF is routing, running rich, requires reroute of SAI pump , rerouteing of n75, rerouting of DV
Modified by waabaah at 11:04 AM 3-24-2010
2. bigger downpipe
