NEED OPINIONS ON CAMS
469 Views 8 Replies 5 Participants Last post by  flawlessG60
Hey - Done the stage iv kit except for a cam, and interested in hearing opinions on cams and which is the best, second, etc. Also are the cams with the asymmetric grinds noticably better? I want a cam with a serious noticeable gain but a half decent price...thanks
1 - 9 of 9 Posts
Re: NEED OPINIONS ON CAMS (flawlessG60)
Considering the only diff between stage III and stage IV is the size of the cam you havent done a stage IV..Stage III is the pulley, chip, FPR, ISV reroute and 260 cam, Stage IV calls for upgraded chip and 268 cam...
Branden
i asked for AN OPINION on cams, not for you to anaylze whether i have a stage 3 or 4, and I do have a stage 4 chip just not a cam thats why i need feedback...thanxz buddy
the 268/260 is what mos people use. That's the stage 4 cam.
quote:[HR][/HR]i asked for AN OPINION on cams, not for you to anaylze whether i have a stage 3 or 4, and I do have a stage 4 chip just not a cam thats why i need feedback...thanxz buddy[HR][/HR]​
no need for an attitude, branden was just trying to clear things up for the new guy.... he know a thing or 2 about the g60 motor
so any info he has you might want to listen up.........
as for the cam.... it all depends on where you want your power if you want to scream past 7000 like i do get a schrick 276 cam if you want some mid/high end power stick with the 260/268.............and if you like to have the power lower in the power band or plan on getting a turbo anytime soon get a 260
See less See more
relax dude. he is right, and really only trying to help you out.
i can give you an opinion on the BBM 268/260 cam. IT RIPS, especially around 4000 rpms and above. buy it, its not cheap... THEN u will be stage iv
See less See more
2
Re: NEED OPINIONS ON CAMS (crez)
sniff sniff..thats it guys Im taking my schrick 272 and goin home
Branden
See less See more
Re: NEED OPINIONS ON CAMS (Padfan1)
ohh yeah I almost forgot isnt flawless G 60 a contradiction in terms?
Branden
thankz guyz...couple more questions from the new guy though...theres a cam shop which has a cam with specs of 225 degrees @50,000 and .440lift @int&eht...would i have too much overlap with a cam of this degree...and is the rsr outlet kit essential?
1 - 9 of 9 Posts
