1 - 15 of 15 Posts
I recently purchased a set of A2 lowering springs to fit on my wagon. Needlessto say I'm anxious to get them on the car.
I am trying to approximate the amount of drop. At the moment I cannot remove my current springs.
I would like to know the off-the-car spring height from anyone who has a set of stock wagon springs collecting dust.
Thanks!
Discussion Starter · #6 ·
No progress yet. I will begin work, hopefully, during my spring break.
Where I live now I do not have access to a set of spring compressors and a 30mm axle socket.
Discussion Starter · #8 ·
Re: (reddfoxx)
@ reddfoxx-
What brand spring did you use? Mine are neuspeeds, with bright green paint.
Thanks for the link. I knew somebody was using them!
Discussion Starter · #10 ·
Redfoxx-Are you also using stock strut inserts?
Or units designed for lowering springs?
Thanks
Re: (reddfoxx)
JP sez:
"The springs are red. I can't recall the brand, but it really doesn't
matter. They are for a MKII Golf/Jetta. The shocks are KYB GR2 in the
front, some unknown brand in the rear."
I swear the springs are yellow. I'll check.
Discussion Starter · #13 ·
Thanks! That helps clear the air regardiing the newish struts I have on the car.
The drop is on a tight budget. I bought the springs for $50. I'll consider new struts, but that eats some of the new tire budget.
Re: (mike in SC)
Glad I was able to help by sitting at my computer, and looking at my car as I got into it.
The front springs are red. There must have been some yellow ones we tried, or just sitting in the shop, 'cause I can see them clearly in my memory.
The rear wagon struts and springs are, I believe, stiffer than the ones in other models. The front struts on mine were iffy anyway, and with the turbo the front end could barely stay on the ground and track a straight line. The KYBs are much better than worn-out stock struts, and of course the springs help too.
New tires made a world of difference as well. The old ones were awful; the new ones, Mastercraft Grand Touring ones, are quieter, grippier, smoother... Assuming the struts are decent, maybe get the best tires you can. OTOH, if you're in there anyway, maybe you should do the struts as well.
Modified by reddfoxx at 1:03 PM 3-31-2010
Discussion Starter · #15 ·
I replaced the struts last summer with some gas shocks/struts on all four corners. The handling was much better! But after an auto-x I decided to upgrade.
I have a set of snowflake rims waiting for new tires.
I'm planning to use the shocks I have on the car now. I am going to take care of the front first. Depending on the drop I might not have to do the rears at all.
1 - 15 of 15 Posts
