Re: Need some lowering advice please.. (amp1080)
...either Bilstein HDs or KONI Yellows will do...
...in my case (H&R SSprings&KONI Yellow on 215/45/17) have to do a front fender roll to avoid rubbing...ride is fine and at the same i can do some adjustment for tight cornering even on daily drving...
...if your only having a 205/45 then you dont need a fender roll...
...also you can do a search on "Bilsteins" or "KONI"...goodluck!
