Re: Need some resistance values for some Bosch sensors (patatron)
bump. I'm sure someone has the Intake Air values.
BTW Eurotrash, I talked to the enigne tuner at my shop about the location of your intake air temp sensor, being that it is inbetween your throttle bodies and cylinder head. He agreed with your neighbor in saying that it should be out farther; specifically, outside of your throttle plates. He said in the bell mouth would be great, but anywhere around the outside of the bell mouth is fine. You just want to know the density of air going into your engine. It doesn't matter if you are picking up a little residual heat from the intake manifold, because we are tuning it accordingly through the megasquirt.
He believes that fluctations in manifold pressure "could" have an affect on air temp sensors, not to mention the exhaust backflow from overlap on your large cams. So it sounds like we might need to relocate it.
-Nick
