Okey, I got everything hooked up. Have the ignition wire hooked into the fuse box to turn it on, have the light wire hooked into the parking lights to light the thing up, and I have the signal wire hooked into the black O2 sensor wire. Heres where it gets weird. First i'm getting hardly know signal. Its just sitting at rich doesnt move back and forth at idle or anything. Plus when you hit the lights it then jumps 2 led positions toward lean..very weird. the ground is good. Then when i had it hooked up to the parkin lights and I tried to turn the lights off they wouldnt even turn off. I had the switch in the off position and they wouldnt turn off. When i pulled the gauge wire for the light out of the parking light fuse then the parking lights worked fine. This is really confusing the hell outa me. Anybody know what the problem could be here?? I also have an oil pressure gauge hooked up and that is working fine. Its getting a good reading and when i hot the lights its fine. Just the A/F gauge is being stupid. Both the gauges are autometer lunar series and the car is a 93 corrado slc. any help would be appreciated.
thanks
troy
[Modified by 93VdubSLC, 10:02 PM 8-5-2002]
thanks
troy
