1 - 1 of 1 Posts
OK here's the problem. purchased a 93' SLC for $4500 with 100,000 on the clock.reason for it being so cheap is that it had no second gear - not engaging and not even grinding- so i pulled the tranyy last week. Split the casing and was shocked to see what happened. the second gear was jammed. so i took a small steel punch and tapped on it with a mallet and broke it lose. lubed it up with some ATF, engages perfectly by hand. so then I put the casing on to the point where i could slide the selector shaft back in to see if second would engage. wouldn't engage at all.
don't know what else to try so know i need some expierienced V-Dubbers to help a young V-dubber out. so if u could please leave what ever u think it could be and I would greatly appreciate it.
1 - 1 of 1 Posts
