Re: NEED SPECS (stevelangford)
quote:[HR][/HR]jetta 89 should be cis-e the '90 was the first jetta with digifant,cis-e swap into an A1 is simple, but no huge power gains other than a newer engine and probably a little higher compression[HR][/HR]
Uhh, wrong again. Late 87 was the first digi. It will be a simple swap, esp in the 82 as it was pre air shrouded injectors. Just swap your fuel system, exhaust manifold, and dizzy to the newer engine. It was probably the 100 HP version, unlees it had the dual downpipe in which case it was 105.
