1 - 4 of 4 Posts
I have a 337, with H&R coilovers. I'd like to raise it maybe half an inch all around. Anyone have experience doing this? How much? TIA.
Re: Need suspension work done in NoVA, raise coilovers (genxguy)
I don't know H&R coilovers but have worked with other brands - most likely it's as simple as raising the vehicle, removing the wheel/tire, loosening a set screw and turning the lower spring perch up to the desired height.
Re: Need suspension work done in NoVA, raise coilovers (mgyip)
Quote, originally posted by mgyip »
10 minutes per wheel!
Discussion Starter · #4 ·
The fronts are easy enough... just turn the perch with the tool that's provided. But I am told the rears need to be almost disassembled in order to change the height.
1 - 4 of 4 Posts
