1 - 3 of 3 Posts
Re: need to set timing. At Idle or higher? (steveracer)
Idle. You should set the idle, then set the timing and then repeat.
Re: need to set timing. At Idle or higher? (VWhombre)
Thanks, dude. I checked it and I'm set at 18 degrees advanced, and it pulls strong. I set it to twelve, and I lose power AND gas mileage. What gives? I thought max safe was 12 degrees. Now I want to set it back to 18.
1 - 3 of 3 Posts
