USA. Mk5 GTI DSG.
Hi there. So just coming off a real fun time figuring out/replacing a dead steering rack (water intrusion to J500 module) and I got all sorts of flashy lights and errors. Running VCDS of course, still learning a bunch...
I HAVE previously messed with a few things but there were no codes for months and months. This is a rally cross project so I needed to fully disable ESP (no traction control, no steering aid) in order to be able to slide the car around without any outside interference. Under ABS control module (I believe), I switched to right hand drive which disables stability but maintains ABS. Worked awesome for months. I also changed country code to Australia (I think) to enable fog lights as DRLs. That's it if I remember correctly. Since this power steering fiasco (since fixed) I got a bunch of lights and things are not getting along. Read up a ton but not able to make any progress.
Could the pros and semi pros please chime in?
Thanks.
Latest scan:
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.12.0(x64) Data version: 20201124 DS322.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,05,January,2021,16:24:19:43811
VIN: WVWFD71K99W126018 License Plate:
Mileage: 157730km-98008mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFD71K99W126018 Mileage: 157730km-98008miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0010
Revision: E3H13--- Serial number: VWX7Z0H83NH8AD
Coding: 040301081C070160
Shop #: WSC 00000 000 00000
VCID: 6A8DC758D0755B6BCD7-803E
3 Faults Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157518 km
Time Indication: 0
Date: 2000.00.00
Time: 15:02:13
Freeze Frame:
RPM: 1896 /min
Load: 21.2 %
Speed: 68.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000370 - Fuel Trim; Bank 1
P0172 - 000 - System Too Rich - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157531 km
Time Indication: 0
Date: 2000.00.00
Time: 15:18:45
Freeze Frame:
RPM: 717 /min
Load: 36.5 %
Speed: 0.0 km/h
Temperature: 94.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
VCDS
Self-Diagnosis Log
Page 3
P0172 - 000 - System Too Rich - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157567 km
Time Indication: 0
Date: 2000.00.00
Time: 12:56:51
Freeze Frame:
RPM: 1743 /min
Load: 25.5 %
Speed: 24.0 km/h
Temperature: 90.0°C
Temperature: 16.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Readiness: 0010 0100
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 051 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1942
Revision: 04843012 Serial number: 00000809081839
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 221DEF7868C5432B457-8076
No fault code found.
VCDS
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B600D49240000880B06E592210041B100
Shop #: WSC 59982 001 104857
VCID: 005985F0CA09B13B733-8054
4 Faults Found:
01486 - System Function Test Activated
000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 6
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 320
Count: 50432
Count: 0
Count: 0
Count: 0
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 8212
Count: 50432
Count: 0
Count: 0
Count: 0
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 5
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 220
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 8193
Count: 50432
Count: 0
Count: 0
Count: 0
01487 - System Function Test
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 10
Reset counter: 221
Mileage: 157549 km
Time Indication: 0
Freeze Frame:
Count: 16384
Count: 32768
Count: 13056
Count: 321
Count: 50494
Count: 0
Count: 0
Count: 2304
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A9ED109ED9F9FB4B3-802C
VCDS
Self-Diagnosis Log
Page 6
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008644314
Coding: 178D8F214004150047140000001400000018770B5C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 33331A3CC73FDAA3BE1-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 160908 021 0501
Coding: 00038805
Shop #: WSC 00000
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0420462
Coding: 0000100
2 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 12
Reset counter: 211
Mileage: 106896 km
Time Indication: 0
Date: 2000.00.00
Time: 16:58:58
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 217
Mileage: 157543 km
Time Indication: 0
Date: 2000.00.00
Time: 15:32:43
VCDS
Self-Diagnosis Log
Page 7
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0C137D
Coding: 0013899
VCID: 6C81C140DA81455BBFB-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME40240270X
Subsystem 3 - Serial number: 6342MSME3E51514CH
Subsystem 4 - Serial number: 6352QSME2B0B190EP
Subsystem 5 - Serial number: 6362QSME4F083F1E
Subsystem 6 - Serial number: 63727SME190856762
Subsystem 7 - Serial number: 63827SME071E2027.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 057 0101
Coding: 0012122
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83NH8AD
Coding: 0007104
Shop #: WSC 00000 000 393216
VCID: 392F2814E55320F374D-806C
VCDS
Self-Diagnosis Log
Page 8
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 150908F2000387
Coding: ED811F070013020000
VCID: 35372424C94BC493905-8060
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T456J03
VCID: 7DA7FC04B1FBDCD3185-8028
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2416
Shop #: WSC 49949 001 1048576
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 38292D10DE5939FB8B3-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 34311920C231DD9BA7B-8060
VCDS
Self-Diagnosis Log
Page 9
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
Shop #: WSC 22116 444 53185
VCID: 045189E0D211AD1B57B-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D92082B19D9B67B-8020
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 125 0037
Revision: 00125000 Serial number: VWZ5Z7H2261662
Coding: 0040401
VCID: 290FF85415F3907304D-807C
VCDS
Self-Diagnosis Log
Page 10
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
End----------(Elapsed Time: 01:13, VBatt start/end: 13.9V/13.9V)-----------
Thanks.
Latest scan:
VCDS
www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log
VCDS
Self-Diagnosis Log
Page 2
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157518 km
Time Indication: 0
Date: 2000.00.00
Time: 15:02:13
Freeze Frame:
RPM: 1896 /min
Load: 21.2 %
Speed: 68.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157531 km
Time Indication: 0
Date: 2000.00.00
Time: 15:18:45
Freeze Frame:
RPM: 717 /min
Load: 36.5 %
Speed: 0.0 km/h
Temperature: 94.0°C
Temperature: 21.0°C
Voltage: 13.716 V
VCDS
Self-Diagnosis Log
Page 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157567 km
Time Indication: 0
Date: 2000.00.00
Time: 12:56:51
Freeze Frame:
RPM: 1743 /min
Load: 25.5 %
Speed: 24.0 km/h
Temperature: 90.0°C
Temperature: 16.0°C
Voltage: 13.970 V
Coding: 0000020
VCDS
Self-Diagnosis Log
Page 4
Revision: 00H45001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 6
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 320
Count: 50432
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 8212
Count: 50432
Count: 0
Count: 0
Count: 0
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 5
Fault Priority: 2
Fault Frequency: 2
Reset counter: 220
Mileage: 157543 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 13056
Count: 8193
Count: 50432
Count: 0
Count: 0
Count: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 221
Mileage: 157549 km
Time Indication: 0
Freeze Frame:
Count: 16384
Count: 32768
Count: 13056
Count: 321
Count: 50494
Count: 0
Count: 0
Count: 2304
VCDS
Self-Diagnosis Log
Page 6
Coding: 00038805
Shop #: WSC 00000
Coding: 0000100
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 211
Mileage: 106896 km
Time Indication: 0
Date: 2000.00.00
Time: 16:58:58
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 217
Mileage: 157543 km
Time Indication: 0
Date: 2000.00.00
Time: 15:32:43
VCDS
Self-Diagnosis Log
Page 7
Coding: 0013899
Coding: 0012122
Coding: 0007104
VCDS
Self-Diagnosis Log
Page 8
Coding: 0001077
VCDS
Self-Diagnosis Log
Page 9
Coding: 0001076
Coding: 0000003
1 Fault Found:
Coding: 0040401
VCDS
Self-Diagnosis Log
Page 10
Component: RDK 0450
Coding: 0100101
