1 - 20 of 179 Posts
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (dcomiskey)
So, can you actually feel the difference and does it have more understeer or oversteer? The only concern I have about installing the rear sway bar is that it might disrupt the beautiful handling balance of the 337! That is a very pretty sway bar. http://****************.com/smile/emthup.gif Please keep me informed.
awesome pics man!!!
just exactly what i needed!!!
i've had that same bar at my house for over 2 weeks now, just waiting for my car to come back to me before i install it...
so does the bar make our cars feel like a RWD??? hopefully yes
do some donuts!!!!
once again, great pics!!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Discussion Starter · #4 ·
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (milo)
Milo, go back and read my original post about the bar. Your questions were discussed to death earlier in the week.
Disrupt the handling??? LOL!!
Devin, Excellent instructions!!! As this thread will likely fade away at some point in the future, do you have a host you can post this to for future reference? If not, may I suggest http://www.vwmkiv.com/ under the "how2" section. It's not my site, but it always seems to be there and is consistent with the quality you've put together........ http://****************.com/smile/emthup.gif
[Modified by david equitz, 6:51 AM 8-2-2002]
Banned
quote:[HR][/HR]So, can you actually feel the difference and does it have more understeer or oversteer? The only concern I have about installing the rear sway bar is that it might disrupt the beautiful handling balance of the 337! That is a very pretty sway bar. http://****************.com/smile/emthup.gif Please keep me informed. [HR][/HR]​
Dont lie Milo, your only concern is blowing more money on your car when it doesn't work as advertised <cough> APR AND CARBINO </cough>.
Discussion Starter · #11 ·
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (RubberDubbie)
quote:[HR][/HR]Nice install instructions and pics.
What's with the M&Ms?[HR][/HR]​
Thanks!
OH, if you order from Parts4VWs you to pick a free pack of M&Ms.
Milo and all the other Austin folks, I have the Autotek bars installed (F&R), so if you want to get a sense of the handling with bars (which is monstrous...like a different car) I'll meet up with you at the next GTG and give you a ride. There are some differences in the designs, but same outcome as the Neuspeeds.
BTW, got APR chipped last weekend at QRS... all is well.
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (cameron355)
DC. Great work! http://****************.com/smile/emthup.gif I'll be doing this mod real soon. This will be a good resource.
Can anyone chime in on comparo's between the Autotech-hollow vs. Neuspeed? Big or subtle differences?
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (Adonis)
The Autotech bar is pretty much the same install but instead of the clips, you drill two holes in the rear axle beam (not that hard) and bolt the inner supports to that.
Ride is mucho improved.
Nice write up DC!!!
Discussion Starter · #15 ·
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (TreyS)
Thanks, Trey.
Yeah, you can't really go wrong with any bar. There are subtle differences in each (25 or 28mm, solid/hollow, etc.), but realistically speaking, unless you are into SERIOUS racing, I honestly don't think it matters which one you go with. With my experience, I'd go with the NS in the future, but that wouldn't stop me from recommending ABD or Autotech or whatever. They're all just as good. I specifically got the NS because I have the ability to adjust it (3 settings).
dcomiskey, Very nice and detail instrucation, I just saved it and I am looking forward to install my future rear sway, thanks. http://****************.com/smile/emthup.gif
Banned
Milo, next GTG we meet up at you can take mine for a spin. Check out the handling. I, of course, will have to be in the car with you...
Banned
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (Chef337)
Get under the car again and lube the two unethane bar holders by the axel, if they wern't alredy lubed. If they get dry and stick while transferring force from one side to another, it will upset the car, and you don't want that while cornering hard!!! Also with this bar it ends right where the coilover adjuster will come through the spring perch when you buy coilovers!! If you put coilovers on you will have to drop the bar so much what it becomes a clearance issue!! The only style rear bar that won't be an issue is a Shine/Obar type.
That said....The bar works well! and too boot it looks kewl too!
Re: Neuspeed 28mm Rear Sway Install Instructions on a 337 (ZinK)
dcomiskey, AMAZING write up!!!!!! exactly what i needed. thanks, bro. i can finally feel confident to do this myself. my swaybar has been sitting in my garage for like a month! i can really appreciate the time and effort you put into taking the pics and thinking of how to make the directions clear and easy to follow for n00bs like me. WTG!!!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
1 - 20 of 179 Posts
