Ok so I was in the process of building a n/a aba with a fully ported and polished head and a tt 276 cam, tt adjustable timing gear, eurosport lightweight intermediate shaft pulley, gruvenparts lightwieght crank/alternator pulley and lightwieght tensioner roller, obx header, dehumped and polished throttle body, new south power gasket, test pipe bolted then to a supersprint exhuast, probably forgeting somethings but you get the jist.... I just was offered a deal I can't pass up on a nuespeed supercharger set up!! So know plans have changed and I'm going to be using all the pieces I have already except the cam oviously. And am going to purchase or trade for a 260/268 cam. Planning on messing with pulley options.. Any help in that department from experienced peoples is greatly appreciated! I have no ac in my car by using the vr6 water pump pulley.. Where can I get a seep belt that fits??? Or what size do I need? and am planning on deleting that pesky evap stuff??? To the left side of the bay on my obd 2 golf. Now if I do that and run nuespeeds software for the charger will I throw a check engine light? Or should I get a different chip suited more towards my exact set up? Any help greatly apreciated and or is there anything I should change from my previous set up to better suite my new FI
setup ? What fueljg upgrades should I do if I ran smaller pullies? Given I would have to get a new chip .Thanks in advance. Jon
