1 - 8 of 8 Posts
FRONT ANTI-SWAY BAR - 25MM JETTA IV
With smooth mandrel bends, aerospace-quality steel, machined ends, polyurethane bushings and much more, Neuspeed sway bars give you the ultimate in handling. Neuspeed sway bars reduce body roll without sacrificing ride comfort during straight-line cruising.
Notes
The NEUSPEED front anti-sway bar is a must-have item for all lowered Golf IV, Jetta IV and Beetle vehicles. The factory front bar can strike the driveshaft when the suspension is compressed. NEUSPEED's front bar features a correctly engineered arc to provide the additional clearance that lowered cars need. NOTE: Professional installation recommended. $289.95
REAR ANTI-SWAY BAR - 25MM BEETLE/GOLF/JETTA IV
With smooth mandrel bends, aerospace-quality 6150 steel, machined ends, polyurethane bushings and much more, Neuspeed sway bars give you the ultimate in handling. Neuspeed sway bars reduce body roll during cornering without sacrificing ride comfort during straight line cruising.
Notes
3 position adjustable rear bar. To create the ultimate performance suspension, add a NEUSPEED front anti-sway bar, KONI or Bilstein shock absorbers, and NEUSPEED lowering springs. $289.95
FRONT ANTI-SWAY BAR - 25MM BEETLE/GOLF IV
Notes
SPORT SPRINGS - 1.5F / 1.5R GOLF IV VR6 99+
Made in Germany by ISO 9002 certified spring-winding specialists. Neuspeed springs reduce body roll during cornering and front end dive under heavy braking. Plus, Neuspeed spring kits reduce wheel-well gap to create a more aggressive look for your car.
Notes
Lowers approx. 1.5 (F) & 1.5 (R). Photo is for illustration only. Actual color may vary by kit. $249.95
SPORT SPRINGS - 1.5F / 1.5R JETTA IV 1.8T/TDI 99+
Notes
Lowers approx 1.5F / 1.5R. Photo is for illustration only. Actual color may vary by kit. $249.95
UPPER TIE BAR - POLISHED/BLACK GOLF/JETTA IV
Neuspeed Front Upper Strut Tie-Bar. Connects the left and right side upper strut mounts in your engine compartment to increase chassis rigidity. The result is improved steering response, especially on cars with high performance wheel & tire packages.
Notes
Single 1"tubular cross bar with a solid 4 point mounting system. Fits all Golf IV and Jetta IV models except 24-valve VR6 models. $129.95
P-FLO AIR INTAKE KIT - WITH STAINLESS HEAT SHIELD GOLF/JETTA 1.8T 99+
Would you ever run a marathon breathing out of a small paper bag? So why ask your engine to rev all the way to redline breathing through the restrictive factory airbox? The plastic factory airbox is good at muffling intake noise and enhancing low rpm/low speed engine performance, but becomes very restrictive when the engine is operating in the higher rpm range – where most performance drivers need it. The NEUSPEED P-Flo allows you to uncork the intake side of your engine, drawing in a nearly unlimited supply of fresh air. Most applications gain an honest 5-8hp at the wheels in the midrange and higher rpms (depending on the vehicle.) Plus, every P-Flo kit includes a high-performance, multi-layer cotton gauze air filter that is washable and reusable, and traps dirt better than your original paper filter. You also get an aggressive, deep throaty engine roar when you step on the gas pedal.
Notes
Includes stainless heat shield and snap-on air pump hose connector. CARB exempt # D236-10 when used with a NEUSPEED P-Chip. $239.95
RACE SERIES COLD AIR INTAKE - GOLF & JETTA IV 1.8T & VR6 W/AIR PUMP NEW!
NEUSPEED's new Race Series Cold Air Intake features the largest diameter tubing - 3"for the most free flowing intake available to make the most horsepower. Manufactured using lightweight aluminum tubing, with a black powder coat wrinkle finish, our kit looks good too! Our billet aluminum smog pump fitting is included for clean looks and easy installation. Rubber isolated mounting reduces vibration.
Notes
The Race series intake places the filter element in the front, driver's side inner fender compartment. While this position is somewhat shielded, we do not recommend the Race intake for cars that are frequently driven in wet weather conditions.
For customers living in areas with frequent rainfall and excessive standing water, we suggested that you use our traditional P-Flo short ram system. 259.95
SHORT SHIFTER KIT, 5-SPEED - 2002-UP BEETLE, GOLF IV & JETTA IV W/ PIN STUD CABLE MOUNT
The Neuspeed short shift kit for the 2002-up Beetle, Golf IV and Jetta IV consists of a new steel bracket assembly that easily installs on to transmission's selector shaft. The Neuspeed short shift kit reduces the throw length between gears by approximately 40%. A calibrated counterweight is welded to the end of the Neuspeed bracket to retain a solid feel from gear to gear.
Notes
To determine if this kit is the correct application for your car, first find your factory shift bracket assembly located on the top of your transmission. This bracket is visible by looking below your airbox and battery. Inspect the stock cable linkage that connects to the factory bracket. If the stock cable end has a stainless steel clip, your car has a pin stud mount and this is the correct kit for your car. $219.95
Re: NEUSPEED PARTS FOR YOUR VDUB! (VividRacing.com)
It does not take much work to find this stuff cheaper local or on the web. Nice overview of the products though.
mucho dinero
1 - 8 of 8 Posts
