1 - 2 of 2 Posts
NEUSPEED PARTS FOR YOUR S4!
With smooth mandrel bends, aerospace-quality steel, machined ends, polyurethane bushings and much more, Neuspeed sway bars give you the ultimate in handling. Neuspeed sway bars reduce body roll during cornering without sacrificing ride comfort during straight-line cruising.
Notes
2 position adjustable rear bar. Includes bolt-in subframe reinforcement brackets (not shown in photo.) NOTE: Audi A4 Quattro and S4 rear suspension subframes should be inspected carefully prior to the installation of any rear anti-sway bar. If you find any fractures or cracks in the subframe, repair or replace the subframe prior to installing your new anti-sway bar. $279
SPORT SPRINGS - 2000 - 1.5F / 1.25R
Made in Germany by ISO 9002 certified spring-winding specialists. Neuspeed springs reduce body roll during cornering and front end dive under heavy braking. Plus, Neuspeed spring kits reduce wheel-well gap to create a more aggressive look for your car.
Notes
Fits 2000 S4 models only. Lowers approx. 1.5 (F) & 1.25 (R). 2001-2002 vehicles use part number 55.02.47. Photo is for illustration only. Actual color may vary by kit. $249
1 - 2 of 2 Posts
