Neuspeed Vs. 16V Stock lower tie bar.
518 Views 6 Replies 3 Participants Last post by  Slegato
Which is a better lower tiebar? The neuspeed 2 point or the Stock 16V 4 point lower tiebar? The neuspeed seems a lot thicker then the stock 16V one.
1 - 7 of 7 Posts
Re: Neuspeed Vs. 16V Stock lower tie bar. (Slegato)
I have never seen the 2 point Neuspeed one, but I assume that it only ties both of the control arm bolts together. The stock one, however, ties to the body as well. I would go with the stock one because of the ridgidness through the triangulation. Larger doesnt necesarily (god i cant spell) mean better.
Besides, you can get the stock one from a junkyard for 20 bucks.
Well I really need to find out because I have a neuspeed one but never installed it yet, and if the stock 16V one is better, then I just get one of those. I am going solo 1 racing and want the best tie bar available.
Stock one http://****************.com/smile/emthup.gif This mod helps any a1.
See less See more
Re: Neuspeed Vs. 16V Stock lower tie bar. (RiverBunny)
Is the stock 16V tiebar just a bolt on or do I have to do some more work to fit it?
U will probably need to drill 2 holes for the rear mounting points of the stock bar. No big deal.
Thanx RiverBunny i will look into it.
1 - 7 of 7 Posts
