My emkay4 GLI was in a wreck (not my fault) and I retained it for parts and took the little bit of money the insurance gave me. Scoured the internet and local classifieds for another or similar and came across an Audi. It was about 2 hours away and I took the gamble to go have a look. I lowballed $700 less and he bit and I did, too. Looks to be a head gasket and has all the classic symptoms.
Compressions: #1-170, #2-105, #3-150, #4-170
#2
Everything else works except the HVAC flapper, which I hope is just some foam debris holding it up, but it is in the best position for AC in the south. All 5 matching wheels, covers and screen in storage area work, both keys, plastic key, as well as key number, dealer maintenance logged to 100k, car is at 190k, cupholder works, glovebox did but is now broken by me, about it.
So on the short list is to deck head, head gasket, new head bolts, timing belt, water pump, and new valve cover gaskets. Coolant flush, engine oil flush, and change both diffs fluid and tranny fluid. Then go from there.
Parked behind a Raising Cane’s on the way home.
#2
