Black Forest Industries has recently partnered with Competition Clutch to create a range of clutch and flywheel options for several different Volkswagen applications, MK1- MK4. Offered in Stage 1, 2, and 3 as well as individual flywheels these kits can handle power outputs from mild to wild depending on your goals.
The Stage 1 Kit assembly provides an estimated 25% increase in torque capacity and is properly suited for aggressive street use. The stock organic clutch disc is matched to a performance pressure plate that will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up.
The Stage 2 kit assembly provides an estimated 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up.
The Stage 3 kit assembly includes a segmented ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. Good for 350 – 400 ft lbs of torque at the wheels.
All kits include a performance pressure plate, ultra lightweight steel flywheel, all applicable bearings, and the appropriate alignment tool. (unless otherwise stated)
Contact:
1000 E. Chatham St.
Cary, N.C. 27511
(919) 468 – 5400
[email protected]
http://blackforestindustries.com
